Westside Osprey
Flight distance : 95915 ft
Lipos often puff when overly discharged. I have over a hundred Lipos and I usually retire them once they puff. I certainly would not fly anything expensive with a puffed Lipo.
There is lots of information on the WEB about Lipos and care for them. DJI has simplified charging and balancing as well as storage.
Most Lipos are dumb and you have to do the balancing and storage yourself. There is even a recommended breaking procedure, and that is to only fly gently, no full throttle for the first 10 flights or so and don't discharge below 50% during the breaking period. This will help Lipos live longer and store full or close to full charge longer.
Another key trick to long life with Lipos is never discharge below 30%, I always land at 30%, my absolute limit is 20% any less then that and you may puff the Lipo and the life span will shorten. Personally I don't understand the 8% discharge DJI talks about. Maybe someone from DJI can comment here.
I typically get 500 cycles or more from my Lipos before retiring. Once they don't charge up above 85% or so I retire them. I always store lipos between 35% and 70%, never fully charged. Charge within 12 hrs of flying. If not used then fly them down to 50% to store, even just hovering in your garage if it is raining.
I doubt DJI lipos are different from most Lipos, so I use these procedures on my phantom Lipos.
Here is a good link to Lipo info:
Lipo info |
