CONTROL FREQ
Flight distance : 3762346 ft
It's a good feature to have.
when i first started flying my P3P. I had my RTH hight set to about 200 feet and one day i forgot to set the height to about 300 feet because i flew over a structure that was about 270 feet. anyway, i flew out and was about 300 feet in altitude and lost the signal. i started to panic because i forgot to set the RTH height higher and i thought it would lower itself to the 200 ft altitude that i had it set for, but DJI figured that if you're higher than the set RTH height, it must be for a good reason, so if you're higher than your set RTH height, it will return at that higher height that you're flying at.
...and I sure am glad they designed it that way! |
