duey101
Thailand
I had exactly the same problem and now my iPad mini 2 works flawlessly, here is what I did... this is a post I wrote from the iOS 9 thread.
I think a clean MANUAL install of everything is required to get things working right. Just like when your OS goes bad, a clean install is always the best thing to do. When I turned on my bird today I found it had automatically updated itself somehow from v1.3.20 to v1.4.0010 (latest) and I did nothing to initiate this. So, I went ahead and just bit the bullet, installed iOS 9.1 and then upgraded the RC unit. It was still giving me black screens, dropouts, signal loss, and so on. Worse even yet, on a test flight whenever I would yaw left or right the camera would move violently from side to side and the yaw function seemed really out of whack though all settings were normal. I grounded it and then did the following which seems to have sorted it out.
Updated iOS 9.1 (already).
Deleted DJI GO from my iPad.
Hard reset of my iPad mini 2 after deleting app.
Downloaded and installed DJI GO 2.4.0.Hard reset of my iPad mini 2 after installing app.
Downgraded FW from v1.4.0010 to v1.3.20.
Boot up, check everything on v1.3.20, all settings good.
Short test flight, all was okay, but now RC says FW and Camera upgrade required.
Installed FW v1.4.0010 again MANUALLY from a freshly formatted card.
Reset, re-calibrated everything.
Turned off hardware encoding on my iPad mini 2.
Flew up 200 meters and out 300 meters and all seems good.
A three battery test flight tomorrow will confirm but it seems good as of now and might be sorted out, we shall see!
Note: Turn off hardware decode in the app on your iPad mini once you are up and running. Don't forget to reset your setting, calibrate IMU, Compass and Gimbal too. You should be all good after. I have 100% function and reliability now whereas before I had what you have now, this is how I fixed it. You don't need any other apps, DJI GO works just fine. It has been a week now and several flights without one single isse.
