Cetaman
Flight distance : 2528264 ft
Aloha Roger,
We do that a lot here in Hawai'i. In this case, it would be useful if Venezuela took off the lens cap. It is just a filter cap and comes off easy. Just make sure it is tight when you put it back on.
Also, unless it fell in distilled water, jag's comment about water spots will probably require that the lens cap come off anyway to remove the spots. The longer the spots are allowed to dry, the harder they will be to remove, so doing it at the beginning allows water drops to be removed (speeding up the drying process) and clean-up is easier.
There is no need to get rice inside the camera since that will make clean-up harder. So place the camera and gimgal carefully so rice and small debris do not get inside. That dry, uncooked rice does a great job and it is real cheap.
roger, should we tell them to use Calrose or Hinode rice? The kine for rice cooker?
Aloha and Drone On! |
