I have a had afew times the the Gimbal will lock into the staight down position. It will acutally require a physical , by hand releasing movement then return to normal operations.
Any ideas?
thank s, MIke
Pressing the C1 button on the underside of the RC unit will cause the camera to alternately switch between the vertical and horizontal position. Are you perhaps doing this accidentally?
