mike.wildlight
Flight distance : 5623 ft
That is really determined by any given job.
On some jobs 0.5m resolution and a few meters in location won't matter.
If your doing volumes or critical elevations then the z axis becomes very important indeed!
I do most of my P3P surveys @5cm/pixel resolution and mostly positional accuracy isn't critical for my purposes. It looks in the range of a few meters or better.
The P3P quotes a hover accuracy of +/- 1.5m horizontal which is different to positional accuracy but a useful guide. You can improve this to survey standard by georectifying with Ground Control Points.
Vertical accuracy is quoted at 0.5m (at survey type altitudes) and is determined by barometer. I haven't done any express measurements but the surveyors I hand some of the results off to seem pretty happy and I think barometric results over the time periods to do a P3 survey would be reasonably consistent.
So unfortunately the answer to your question is "it depends".
Hope this helps a little
