RC Noob
Hi, I am trying to balance my props (both original and carbon fiber). What is strange is that the horizontal balance (props on either side of the Dubro balancer) is relatively easy to achieve with a very small piece of tape (generally) but the vertical balance seems almost impossible to achieve without adding several (and I mean very many) pieces of tape on one side of the space between the propellers. Imagine the props were lined up vertical, and you were looking for them to stay nearly vertical.
I am not quite sure what to do here. I tried with both factory props and the carbon fiber ones (which i love). Of the 5 props that i worked on, only 1 - was I able to balance adequately without adding excess material in that tiny area. I also added as much as I could on both the props on one side of the CG, but it seems a bit much to have to do this.
I have heard of people trimming / sanding the other side? I dont want to touch any control surface (I am not an expert), which means best I could do is shave off some material on the cap on the other side, but i am not sure it will do much.
I could ofcourse just ignore the imbalance, keep the horizontal balance which is very easy to achieve, and call it a day.
Suggestions please!
