I've already tried IMU calibration in a perfectly leveled surface and recalibrated the gimbal. It's not off by a lot but enough to bother me. Is there anything else I can try? What else should I do if either of those things don't work?
DJI-Ken Posted at 2015-12-15 17:43
Are you on the latest firmware?
And when you set the gimbal roll, is the camera straight when you po ...
Yes I'm on the latest firmware. I adjusted the gimbal roll and it helped straighten it. When I power it back up it keeps the setting. Is adjusting the gimbal roll a way to fix the horizon line?
Yes, if the gimbal calibration won't get it straight, then the gimbal roll will do it.
Jusmake sure you're on a perfectly level surface when doing any of the aircraf calibrations.
Unfortunately, my dealer not want to be responsible. He says that I have to send and pay € 100 per shipment. (Also it says that it is I who speak to the media not him).
