Flight Raptor
Flight distance : 3014675 ft
I would like to 2nd this request. If an option is available to use imperial or metric, ALL settings/measurements should change to the option selected. If someone selects metric, then they are all set because ALL settings/readings are in metric by default. If someone selects imperial, the status bars will change to reflect imperial, but many of the actual settings in the app (i.e. the RTH height, max distance, max height), remain in metric.....it can be a bit confusing and potentially dangerous as people are expecting this imperial/metric setting to adjust ALL settings/measurements in the app.
Anyone from DJI that can please pass along this request? |
