Ninety Mile
New Zealand
I recieved my new Phantom 3 Advanced three weeks ago and have had heaps of connection problems. I am using a new Ipad mini 4 with the controller.
I am turning the system on in the correct sequence and connecting as outlined in the manual. I also have sufficient distance between the aircraft and controller to make sure that is not part of the problem. I am also giving it plenty of time for the aircraft and controller to connect.
Sometimes I have to go through the sequence a few times to be successfull. Once I get connected and get the aircraft in the air I cannot switch from auto to manual mode in the camera view. I would not fly the aircraft at and distance for fear of losing it!!
Now, 4 days ago my controller quit working. I packed it away after fully charging the battery and when I tried to use it the next time it would not turn on. Yes, I am also following the correct procedure for turning on the controller. And, no I will not open the controller and remove the battery as to try a re-boot as I should not have to with a product so new.
I have spoken to DJI about this problem and the tell me it is very unusual and it is probably a bad controller. To be fair, DJI says if I return it to the dealer I purchased it from they will replace the entire system as it is so new. Thats cool!! At least I know they back their product
Has anyone else experienced these problems?
This is my first post, so I apologise if it has posted twice.
Cheers, Ninety Mile
