Geebax
It is actually quite easy, but there is a trick to it. Usually you are tempted to grab hold of it too tight, that distorts the filter and it then binds on the thread. It can easily be removed by grabbing it lightly with three fingers, and long as you don't try to squash it. Using rubber gloves also helps.
Also, in case the message has not got across, ALWAYS format the SD card in the aircraft, it KNOWS what format to use, you may not. And in doing the format in the camera, it also sets up all the files and hidden directories it needs.
