terrylewis
Flight distance : 3517287 ft
1. Do I have to update to v1.6 or can I fly it as is?
You may fly as is. You currently have control of updates...
2. If I do the update to v1.6 does the battery automatically update as well? If not how do I do that?
The firmware includes modules for multiple components and only updates those components that need updating. So when you first update the aircraft, the battery installed also gets updated. To update additional batteries, just power down, swap a new battery and re-run the update. Only the newly inserted battery will need update and its firmware will be updated (the center two LEDs on the battery will flash while updating as a visual clue - and it will run quickly compared to the whole aircraft update.)
3. I purchased a 2nd battery, will it update automatically once installed with the newly updated firmware on my P3P?
No, the GO App will tell you that the battery needs updating. Grab an SD Card, put the bin file back on it, and simply update the new battery, just like your additional batteries.
4. If I don't do the firmware update does the 2nd battery update to the firmware that was originally installed or is there something I need to do?
Not sure about this question.... Updates are a deliberate user push process. You're in charge... So a battery won't update any other firmware. The bin file updates firmware. Even with the current RC, your mobile device downloads the "bin" file and pushes it to the RC... Ask again if this doesn't address your question...
5. I have a Nvidia Shield for my tablet & it is a bit heavy (Wobbly) mounted on the controller, has anyone figured out how to secure their tablets better?
I have an Air2 and one of the first things I did was to purchase an Inspire METAL device mount. The metal bracket is solid as a rock and available via the DJI Store.And they are interchangeable.
Just looked for link to Inspire mount and it's not offered currently on the DJI Store, but is available here:
http://www.amazon.com/gp/product ... Id=EGCD7TS4Y4U7RBRH
