davebdavies
Hi, I have a cheap 2 axis gimbal fitted to my flamewheel and it works well.I wanted to use naza to control the pitch angle during flight and wired it all up.All works well in naza assistant ie it all shows as working,except the gimbal does not actually move when the associated knob on my tx is turned.
Anyone have any ideas? one theory i have is that only the signal wire is connected from the naza to the gimbal as the gimbal runs on 12volts.I was wondering if connectig the ground wire may have the desired effect and get it to work.Or am i missing something else?
Any help appreciated.
Thanks.
