GTDrone
Flight distance : 2197703 ft
Guatemala
Range , the standard use WIFI if you are outside of USA you get 500 meters or less of range (i get 100 meters in the city ), with the advance it use light bridge you get more than a Mile every where
Controller : basically more buttons and also you can add a HDMI module on the adv , in the standard you wifi and the same thing of range that i mentioned before
Camera : better lens on the advance and better hardware it use a sony lens witch is better , the standard use panasonic lens amazing camera but less quality hardware
Motors : i dont know if it have better performance but in the adv it looks powerful ,
Vision potion , advanced yes , Standard No this is for position holding without GPS or indoors
glonass : advanced yes , Standard No better position holding in the adv but to be honest it works when you are flying around buildings , i own the standard and it has an amazing gps position holding so i think that there is not much difference
support : there is more support for the adv and pro
Hardware : better hardware inside , if you crash and broke your gimbal you can buy a 4k camera and use it in the adv , the standard use a different hardware and you cant upgrade anything
Fly time : standard 25 min , adv 23 min
Board: yes there is a difference you cant use the parts of the standard in an advanced or viseverse ,maybe some modules but not all
that are basically all the differences
