I just got my phantom 3 advanced wednesday and maidened it this morning. on the second flight it tried to autoland and it crashed into the house. everything was fine except for a broken prop. All the motors still worked at this point. After i replaced the battery and went to fly again i got the dreaded esc status error. Upon closer inspection i found that one of the motors has a copper wire on the inside broken. Coould this be the cause of my troubles? if not what is (other than a bad esc)
The broken wire will be a result of the crash, wires don't spontaneously break in flight. It they did your aircraft would be trashed, not try to autoland.
i never said that it just broke in flight, i understand that something probably got in there and broke it in the crash. when you say fix the wire you mean replace the motor right?
