pantera989
New Zealand
Makes sense.
Couldn't test flying at the moment as it's been raining all day, so all these are taken with the camera on a tripod, and the DJI sitting on a solid box, roughly the same height. I was slightly off on the framing, the DSLR came to 22mm vs the 20mm of the DJI. I was going to use my 24-70 f2.8 so I could use the same aperture as the Phantom, but figured similar framing was more important. Used live view on the DSLR to manually focus on the mesh screen in the garage. Due to the large sensor of the DSLR, Depth of field will be smaller, so objects closer and further away then the mesh will more out of focus then the DJI's small sensor.
Further note, this is about as unfair a test as possible for the DJI, comparing and much larger, heavier and more expensive lens/camera combo. It would require something like the DJI S1000 to even get this thing off the ground. Secondly, the cropped images are extreme pixel peeping, there is almost no example I can think of that you would actually view and image that close up.
DSLR & Lens: Canon 1Dx with Canon 16-35 F4 (Shooting RAW)
DJI Phantom 3 Advanced (shooting RAW)
Raw images where imported into Lightroom CC, the DJI images where cropped to 3:2 aspect ration to match the DSLR (loosing some vertical resolution, but keeping the full width resolution). Images where then exported from Lightroom to 100 quality JPEGS, at resolution of 2048 pixels across and uploaded to flickr.
ISO100 images:
DJI:
1Dx:
DJI Crop:
1Dx Crop:
IMO, the DJI holds up pretty well when viewing images at normal web sizes, it does get a bit muddy in highly detail areas like the leafs of tress. I'm guessing it's largely down to the lens, as there isn't a huge difference in MP of the sensors (12.4 vs 18MP). One area I haven't covered here is Dynamic range, and ability to pull shadows, although I was very impressed the DJI's RAW files abilty to recover highlight and shadow detail, I dought it would hold up the 1Dx's much better sensor, and frankly, I wouldn't expect an $700 NZ (cost of Phantom 3 gimbal/camera module here in NZ) to compare to an $10000 NZ DSLR and lens. Looking at the crops, the difference becomes a lot more apparent.
I've also done an ISO 1600 comparison that I'll post shortly.
