ge0se
Flight distance : 3184721 ft
Is the lens completely balanced on the gimbal? What's the shutter speed? If in order to reduce the light to proper levels you bump up the shutter you'll get this jello effect. Keep shutter low, usually at double your frame-rate, so for 30 FPS you want shutter speed fixed at 60 and reduce light using aperture or ND filter or lowering ISO.
Simply remember this - high shutter speed values = jello effect when bird's in the air. |
