Naza-PA
I have applied all latest updates and everything works fine. There was some bad battery bugs in 01.05.0030, I would just go to the latest. Any stability issues - just recalibrate IMU on "true" leveled surface. Get digital level from HD. I have removed glued in magnets with screwdriver on mine to prevent any accidental damage to the sensors and my watch. Unfortunately all levels have magnets, just need to find one made from magnetically neutral (Alu, plastic) and where removing magnets is not violent and it would not compromise the level or its calibration. Drone should stand straight and steady. Inspect the drone legs, some rubber pads may be damaged or the leg could be bent after crash. Some drones may just have damaged parts of the case due to crash (some may have sensors unit (LB) not installed/aligned correctly so when you level the drone it is still off inside of it, but this it is very rare). In this case, fix the leg or pad first or level craft using tops of the motor shafts. The goal is to get sensors unit (inside) leveled before calibration. Without it no FW would help as it simply has no level reference point. |
