RPM aerial
Flight distance : 38593 ft
Ok so I was going to do a firmware update. Last update was to 1.4, so I updated the RC first using the GO App. all went well and no problems. Then downloaded the 1.6 firmware to the SD card and put it in the camera and turned on the AC. Immediately things went bad as I had forgot to turn off the RC with the iPad mini connected to it.
Now there is no longer any tails light. The AC is emmitting a loud beeping and the Camera is beeping at a constant rate D-D-D-D-D-D-D-D....
The RC now says MC Connection to the center cboard has failed
Solution: Restart the aircraft, if the problem persists, contact DJI Support
Gimbal cannot receive MC data
Solution: check the 8-pin plug that connects the damping plate and the aircraft. Ensure that none of the pins are loose. If the prolem persists, contact DJI Support
I have tried reformating the card as suggested with the App, but it jsut times out.
So I reformed another card on the computer and put the firmware on it, It has been going for 30 minnow, but not looking promising.
Am I missing something? Is the card to be formated to exFAT or FAT32 if doing it from the computer? |
