AG0N-Gary
Flight distance : 700846 ft
Run it down to two solids. By the way, I would reset the timeout on the battery to something shorter than the 10 day default. I'm currently set at 3. And, if you hit the battery check function (press the button once), it will reset the timer if it hasn't run down yet. So, just let it be and check it 5-6 days down the line to see if it properly discharged. Mine go down to 2 solid, 1 flashing when I let it auto-discharge. If you have an IR thermometer, you can see when it is discharging. You can just barely tell the difference in temperature with your fingers, as it is a very slow (several days) discharge rate and only raises the temperature about 1 to 1.5F higher on the IR thermometer. I keep one discharged and one charged and compare to the one that is already discharged to see if it has started the process. |
