nigelw
Flight distance : 518084 ft
You said yourself, the aircraft flew fine with the standard DJI props, but not with the aftermarket ones. Seems pretty straightforward to me.
You could try them again & see if you get the same problem, but I would advise against it. Other than that, all you can do is stick to the DJI ones & hope it doesn't happen again. If it does happen again, chances are it isn't the props & you have cause for concern.
There's more than just balance that could be wrong, it could be the thread isn't square to the hub, or the profiles are different between props, or even between blades on the same prop. Unfortunately, many things are cheaper to buy because less money has been spent on design, production & quality control.
We all understand the point of the post, what we're trying to suggest is don't use cheep props in the first place. It's not convenient to have one break 400ft in the air! |
