Kneepuck
Flight distance : 275105 ft
altitude is determined by the internal barometer, not by the gps. When you start the motors, the Phantom reads the gps and the barometer to set the home point. To the Phantom, that initial home point is 0 feet altitude. So it is possible , when flying into a canyon for example, to show an altitude less than 0 feet. And also, max height is determined by the initial home point altitude. This is good, because if the Phantom considered sea level to be the 0 feet point, you could not take off if you were up in the mountains. |
