Geebax
Phantoms have been known to tip over under the following conditions: If you land the aircraft and leave the motors running, then try to lift off again, the aircraft can flip over. This happens because the aircraft, even though it is on the ground, does not know it has landed, so it is trying to stabilise itself in a hover position. As soon as you lift off again, it may try to jump to a completely different position where it thinks it should be. It can flip over in the process.
The answer to this is very simple, if you put the aircraft down, ALWAYS shut the motors off and the aircraft will be happy that it has landed. If you want to take off again, go through the normal motor start routine.
