DJI-Dave
Ok here it is.
For no signal problems with the I1 and P3
Have you removed the App, power cycled the device and reinstalled the App? Make sure that debug is enabled. Click on the HD icon and select custom. Choose the channel that has the least interference, -100 is best. Then set the transmission rate to 4mbps. See if that helps you. Also make sure that all apps running in the background are off, the phone is in airplane mode and video caching is off. If that does not work try a different cable or a different device.
Try leaving the P3 and RC turned on unplug the usb shut down the app replug Usb and restart app.
Try downgrading the firmware.
Try to rebind the p3 to the controller. You push a button on the gimbal with a paper clip and then in the pilot app settings select "linking rc" after pushing the button on the P3. That should re sync them.
It could be a bad USB port that need to be replaced.
Dave |
