chris
Very disappointed so far with the level of technical help regarding this issue considering this is supposed to be a 'pro' section of the forum. Let's see if DJI can redeem themselves.
I have tried the A2 flight controller with a BRAND NEW OUT OF THE BOX H3-3D gimbal and I am seeing the same problem, you CANNOT CONTROL THE TILT.
Lets got through the settings>
Gimbal controllers are always connected to CANBUS 2 (and NO, not at the same time) They don't work on CANBUS 1 either.
In A2 Assistant the Zenmuse channels Tilt and Mode are mapped to 2 suitable RC channels. The sliders move fine when viewed in the RC mapping page.
When I go to Menu > Basic - Gimbal Channel the TILT slider moves in conjunction with the RC as does the MODE slider, everything is fine.
The Tilt Control Gain is set to 50, Horizontal and Vertical limit set to 15 degrees.
Now I disconnect the USB and connect to EITHER the H3-2D or H3-3D relevant Assistant Software
The software recognizes the gimbal and changes so it only shows the Tilt slider.
On changing the tilt control on the RC the TILT SLIDER DOES NOT MOVE and NEITHER DOES THE GIMBAL
The two Gimbals at all time operate normally in terms of balance.
I have noticed that the Tilt Control Gain, Horizontal and Vertical limit settings sometimes revert back to random settings on power cycling the system.
The H3-3D Gimbal frequently makes shreaking noises when powering up.
Versions as follows>
H3-2D
Assistant Software Ver 1.1
GCU Ver 1.14
IMU Ver 1.12 Hardware ID 11E42FD0
CMU Ver 1.0
H3-3D
Assistant Software Ver 1.4
GCU Ver 1.14
IMU Ver 1.12 Hardware 11E42FD0
CMU is blank
A2 Assistant version 1.9
A2 Firmware version 2.7
As I have said let's hope DJI can address this issue considering the amount of money I have spent.
Regards
Chris Horsfield |
