sigilwig44
Hello! I actually have a P2V+, however I'm coming to the P3 forum, mainly because it's an issue that shouldn't matter between the P2 and P3, and there's much more traffic over here on the P3 forum.. Anyhow,
I haven't flown my drone in a good solid 2 months it's just sort of sat in its case. Anyhow, I needed to use it for something tonight, so I pulled it out. I started it, took it off as I nomally would, and the flight seemed to be fine. However, after about 30 seconds, the red lights started flashing rapidly on the drone, and I was like; "LOW BATTERY?!?! That battery said that it was full 30 seconds ago!" So I just assumed that it was the auto discharge feature built into the batteries, so I charged up the battery and tried again, and the same thing happened. I tried a different battery, and the same thing happened, then I tried a third, and that one seemed to be good, but after about 5 minutes of flying it did the same thing. I should also note that a couple hours after this flight, the batteries show that they have almost a full charge, even though I'd discharged them to what the had said was "16%" before, so it seems more that it thinks that the battery is draining faster than it actually is.
I've had this trouble before with a battery, but only one. I just assumed that it was that battery, but now pretty much all of them are doing it. Do I have 6 bad batteries on my hands?! Is there some sort of a reset I can perform? Any ideas are appreciated, thanks.
