nigelw
Flight distance : 518084 ft
Hi Antonio, I'm glad you like what I write & learn something from it.
I have downloaded & processed your DNG file in Lightroom & found it's not a bad image. I did have to run it through the DJI DNG Image Cleaner though to get rid of a lot of white spots (in downloads section). Other than that, it looks ok. There is some distortion showing at the bottom corners, but this is quite normal for an ultra-wide angle lens. The trick is to not have straight edges in the corners so it doesn't show up so much. Point the camera down more & if the corners still bother you, you can crop them out.
Here's the file processed in Lightroom with lens correction applied, contrast & tones adjusted & sharpening added. If you've not learnt how to process a DNG file, it might be best to shoot RAW + JPG to get a good finished file plus a RAW file in case adjustments are needed or just to practice on.
Also, you need to change the format. You're shooting 16:9 images (8mp), change it to 4:3 (12mp) in camera settings.
