Phantomski
Flight distance : 14869882 ft
Once out of beginner mode, unless you set it, the only distance limitation is range. The vertical distance is limited to 500 meters max, and in us, 400ft is the "legal limit" set by FAA. Technically FAA also says you cannot fly outside of line of sight.. well... line you may maintain, but seing your drone once you went further that 1000ft is a challenge.. even at nigh ;) |
