oj88
Flight distance : 36916 ft
That bit of +30° pitch is a leeway used for stabilization. Particularly, if the Phantom needs to move forward, it can do so up to 30° forward tilt without affecting camera pitch. Though, you'll get to see the props in the frame too, so...
For the same reason, the gimbal can go past the -90° (up to -120°, I think).
You can unlock that +30° pitch in DJI Go by turning on Gimbal Pitch Limit 30° extensible in Gimbal > Adv. Settings. However, you can't go beyond -90° manually. It's only available for stabilization. |
