DJI-Amy
You can only downgrade to the previous one, which is v1.3.20 in your case, the method is copy the 1.3.20 BIN file into the aircraft and turn on the aircraft to downgrade, it's the same as upgrade. About the focus, the new firmware will not affect it, what is the temperature of your environment, please try to let the camera work at the temperature of 0-40 degrees. |
