my lightbridge want not work...
1800 6 2014-9-30
chris
Indonesia
hi guys,
i have a big problem.. since the beginning im not able to make work my lightbridge..
before i try to send them back i need to try a last thing, changing the micro hdmi cable that connect the airsystem with the gopro.
please where can i find this cable???
please consider cim sitting in wheelchair so fpv for me its like legs..
thx
chris
-phantom 1 + zm 2d gimbal + gopro
-phantom 2 + zm 3d gimbal + hero 3 + + lightbridge + cinemizer fpv
2014-9-30
destinrepaint
mine was a pain to get started but I got I working now. little over rated in my book. I hope it grows on me a little more. it will not work if you don't have a video . is both green light on ? air unit
2014-10-2
destinrepaint
I used the av cable it started working and pluged hdmi and then it was workin. got to play with it
2014-10-2
Blade_Strike
Flight distance : 872694 ft
Chris to test just try to use a standard hdmi cable. Make sure the gopro is set to a supported output.
2014-10-3
chris
Indonesia
oki guys.. situation.. both lights green, go pro set to 1080/30fps,new hdmi cable.. NADA.. ok, not yet seen the av stori.. will try and let you know..
btw.. it is normal, LB is so noisy?
2014-10-3
chris
Indonesia
av no way how???
2014-10-3
chris
Indonesia
last update.. restart from zero, disassemble all and reassemble. plug in airstation, gopro on, 1080/60 fps,  usb and android with groundstation connected, swith on phantom, on groundstation.. juhuuu it works..
fitv hdmi of cinemizer and works... go out and around perfect.
switch all off.. connect futaba with groundstation, switch all on.. image in android frozen, cinemizer works, try to reset android no way, change to pad no way. all off and again all on... :@ ALL BLACK AGAIN..  what do i wrong what potential can be wrong.. ?
2014-10-4
