Donnie
Flight distance : 3636782 ft
Try these ideas on the links posted below: Make sure your antennas are not crossed , or faulty cable from Transmittter to your device , Watch the antenna tutorial. The compas calibration wont help this problem, what hat I believe you are descibing ( NO signal Video) . I want to give you some advice on how to perform compass and imu cal.
When calibrating compass, do it in a wide open field with no metal around you or on your person, no keys in pocket, no wrist watch, no change in pocket. Also dont do it over concrete becuse of possible re-bar within it, also keep transmiiter at least 3 meters away. Do you compass calibration well on time and only repeat after a hard landing, or firmware update, also do it if you travel more than 150 miles from the original calibration point. Same with IMU Calibrationa do it once on a PERFECTLY firm FLAT Surface and dont even breath or come near it till finished , about 10 min. The reason is the IMU is SUPER sensitive to vibration, even in the floor vibration when approaching it.
Keep in mind there is a difference beteween" No Video signal " and " No RC signal" or "GPS Lost " What I believe you are describing is No Video Signal, meaning you had full control of the aircraft just no live video from the aircraft . The first link tutorial below will help with your settings.
Good Luck- Donnie
http://forum.dji.com/thread-39021-1-1.html Items to check to insure good video reception.
http://www.youtube.com/embed/HoTdK7izUAA Compass and pre-flight basics
