creative noodle
Flight distance : 40446 ft
Thanks for your reply Donnie. Here are the answers to your questions:
Q. Does the X3 work on the Inspire?
A. The X3 came with the Osmo, so I'm not even sure it's supposed to work on the Inspire, though I guess I could try.
Q. Is this a Raw or the Standard X5
A. The X5 is Standard.
Q. When you hooked up the X5 for the first time did you hook it up to the Osmo first or the Aircraft ?
A. I tried the X5 on the Osmo before I tried it on the Aircraft.
Q. When you received the X5 back from service did you update it or was it already updated?
A. On the Osmo, it said FW version unknown. I then tried to upgrade to the Osmo Pro version, but still gray screen.
Q. When your are updateing the Aircraft do you have the Transmitter on by any chance?
A. I do believe the transmitter was on when I updated, and that is probably why I have the "gray screen of death." Let me also note that this "gray screen of death" did not happen instantly and 100% of the time. At first it would start gray and then video feed would get through in 1-5 minutes. The next time I went out to fly, 1-5 minutes became 10-15. Now, it could be 45 minutes to an hour before the video feed comes through.
Q. Do you leave the Updates on the SD card and Not delete them?
A. I do not leave the Updates on the SD card. I delete them once I'm done with the upgrade.
I am posting the files you requested. Note that the Camera FW Version has a "+" at the end. Originally I thought this was because the firmware included special sauce for the Osmo, but from your comments above (which I'm still trying to understand), the "+" means something else. Maybe it is the problem here?
Thanks again Donnie. Really appreciate your time!
Inspire:
[00012377][01 00] Firmware upgrade finished successfully.
[00012486]Done.
[00012517]Packet [C:\WM610_FC550_FW_V01.00.00.29.bin] resumed, card sn [0x95a44ec0].
[00012598]Packet vlink 01.00.0029 <-> 01.00.0000.
[00012642]Version checking[2]...
[00012679][01 00][05] v0.34.3973 -> v0.34.3973 need upgrade
[00012710][01 01][00] v0.21.3803 -> v0.34.3973 need upgrade
[00012766][01 04][00] v0.1.10297 -> v0.1.3977 need upgrade
[00012806][04 00][00] v1.26.0.44 -> v1.27.0.1 need upgrade.
[00012876][03 05][00] v34.1.0.5 -> v34.1.0.5 need upgrade.
[00012932][03 06][00] v2.3.1.0 -> v2.3.1.0 need upgrade.
[00013012][05 00][00] v3.0.6.1 -> v3.0.6.1 need upgrade.
[00013051][08 00][00] v2.14.9.17 -> v2.14.9.17 need upgrade.
[00013096][09 00][00] v1.8.0.0 -> v1.8.0.0 need upgrade.
[00013192][11 00][00] v3.7.15.10 -> v3.7.15.10 need upgrade.
[00013277][12 00][00] v1.11.0.0 -> v1.11.0.0 need upgrade.
[00013353][12 01][00] v1.11.0.0 -> v1.11.0.0 need upgrade.
[00013476][12 02][00] v1.11.0.0 -> v1.11.0.0 need upgrade.
[00013532][12 03][00] v1.11.0.0 -> v1.11.0.0 need upgrade.
[00015054][15 00][00] v1.1.2.0 -> v1.1.2.0 need upgrade.
[00015111][17 00][00] v1.1.0.4 -> v1.1.0.4 need upgrade.
[00015211][17 01][00] v2.0.0.8 -> v2.0.0.8 need upgrade.
[00015251][19 00][00] v1.0.8.96 -> v1.0.8.96 need upgrade.
[00015291]Done.
[00015320]Firmware upgrading[2]...
[00015408][01 01] Firmware upgrade start...
[00045681][01 01] Firmware upgrade finished successfully.
[00045743][01 04] Firmware upgrade start...
[00083684][01 04] Firmware upgrade finished successfully.
[00084336][08 00] Firmware upgrade start...
[00628927][08 00] Firmware upgrade finished successfully.
[00628970][12 00] Firmware upgrade start...
[00685351][12 00] Firmware upgrade finished successfully.
[00685405][12 01] Firmware upgrade start...
[00742511][12 01] Firmware upgrade finished successfully.
[00742555][12 02] Firmware upgrade start...
[00799470][12 02] Firmware upgrade finished successfully.
[00799516][12 03] Firmware upgrade start...
[00856228][12 03] Firmware upgrade finished successfully.
[00856275][03 05] Firmware upgrade start...
[00913067][03 05] Firmware upgrade finished successfully.
[00913198][03 06] Firmware upgrade start...
[01154386][03 06] Firmware upgrade finished successfully.
[01154451][17 00] Firmware upgrade start...
[01216419][17 00] Firmware upgrade finished successfully.
[01216462][17 01] Firmware upgrade start...
[01270258][17 01] Firmware upgrade finished successfully.
[01270303][11 00] Firmware upgrade start...
[01352063][11 00] Firmware upgrade finished successfully.
[01352119][05 00] Firmware upgrade start...
[01397574][05 00] Firmware upgrade finished successfully.
[01397626][15 00] Firmware upgrade start...
[01436145][15 00] Firmware upgrade finished successfully.
[01438452][19 00] Firmware upgrade start...
[01529426][19 00] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 1404, los = 1, ng = 0, usb = 1).
[01559483][09 00] Firmware upgrade start...
[01617184][09 00] Firmware upgrade finished successfully.
[01617246][04 00] Firmware upgrade start...
[01689056][04 00] Firmware upgrade finished successfully.
[01689097]Done.
[01689131]Version checking[3]...
[01689168][01 00][05] v0.34.3973 -> v0.34.3973 need upgrade
[01689202][01 01][05] v0.34.3973 -> v0.34.3973 need upgrade
[01689335][01 04][05] v0.1.3977 -> v0.1.3977 need upgrade
[01689427][04 00][05] v1.27.0.1 -> v1.27.0.1 need upgrade.
[01689501][03 05][05] v34.1.0.5 -> v34.1.0.5 need upgrade.
[01689581][03 06][05] v2.3.1.0 -> v2.3.1.0 need upgrade.
[01689661][05 00][05] v3.0.6.1 -> v3.0.6.1 need upgrade.
[01689705][08 00][05] v2.14.9.17 -> v2.14.9.17 need upgrade.
[01689786][09 00][05] v1.8.0.0 -> v1.8.0.0 need upgrade.
[01689861][11 00][05] v3.7.15.10 -> v3.7.15.10 need upgrade.
[01689921][12 00][05] v1.11.0.0 -> v1.11.0.0 need upgrade.
[01690040][12 01][05] v1.11.0.0 -> v1.11.0.0 need upgrade.
[01690120][12 02][05] v1.11.0.0 -> v1.11.0.0 need upgrade.
[01690300][12 03][05] v1.11.0.0 -> v1.11.0.0 need upgrade.
[01691042][15 00][05] v1.1.2.0 -> v1.1.2.0 need upgrade.
[01691100][17 00][05] v1.1.0.4 -> v1.1.0.4 need upgrade.
[01691200][17 01][05] v2.0.0.8 -> v2.0.0.8 need upgrade.
[01691252][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[01691299]Done.
[01691334]Firmware upgrading[3]...
[01693655][19 00] Firmware upgrade start...
[01914861][19 00] Firmware upgrade finished successfully.
[01914901]Done.
[01914935]Version checking[4]...
[01914976][01 00][05] v0.34.3973 -> v0.34.3973 need upgrade
[01915007][01 01][05] v0.34.3973 -> v0.34.3973 need upgrade
[01915045][01 04][05] v0.1.3977 -> v0.1.3977 need upgrade
[01915102][04 00][05] v1.27.0.1 -> v1.27.0.1 need upgrade.
[01915178][03 05][05] v34.1.0.5 -> v34.1.0.5 need upgrade.
[01915258][03 06][05] v2.3.1.0 -> v2.3.1.0 need upgrade.
[01915338][05 00][05] v3.0.6.1 -> v3.0.6.1 need upgrade.
[01915430][08 00][05] v2.14.9.17 -> v2.14.9.17 need upgrade.
[01915493][09 00][05] v1.8.0.0 -> v1.8.0.0 need upgrade.
[01915558][11 00][05] v3.7.15.10 -> v3.7.15.10 need upgrade.
[01915639][12 00][05] v1.11.0.0 -> v1.11.0.0 need upgrade.
[01915718][12 01][05] v1.11.0.0 -> v1.11.0.0 need upgrade.
[01915818][12 02][05] v1.11.0.0 -> v1.11.0.0 need upgrade.
[01915898][12 03][05] v1.11.0.0 -> v1.11.0.0 need upgrade.
[01916008][15 00][05] v1.1.2.0 -> v1.1.2.0 need upgrade.
[01916058][17 00][05] v1.1.0.4 -> v1.1.0.4 need upgrade.
[01921163][17 01][05] v2.0.0.8 -> v2.0.0.8 need upgrade.
[01921211][19 00][05] v1.0.8.96 -> v1.0.8.96 need upgrade.
[01921244]Packet upgrade finish successfully.
[00013222]========== remo-con disconnect. boot(15) ============
[00013253]Firmware [C:\INCAMBCPUFw1.bin] detected, card sn [0x60ce45f6].
[00013291][01 04] Firmware upgrade start...
[00049502][01 04] Firmware upgrade finished successfully.
[00049542]Done.
[00013686]========== remo-con disconnect. boot(15) ============
[00013719]Firmware [C:\INCAMBCPUFw1.bin] detected, card sn [0x70ce40a3].
[00013848][01 04] Firmware upgrade start...
[00047878][01 04] Firmware upgrade finished successfully.
[00047915]Done.
[00013698]========== remo-con disconnect. boot(15) ============
[00013730]Firmware [C:\INCAMBCPUFw1.bin] detected, card sn [0x00ce0866].
[00013771][01 04] Firmware upgrade start...
[00051055][01 04] Firmware upgrade finished successfully.
[00051097]Done.
[00012768]========== remo-con disconnect. boot(15) ============
[00012803]Packet [C:\WM610_FC550_FW_V01.00.00.30_gimb.bin] detected, card sn [0x9b116120].
[00012840]Packet upgrade start...
[00012885]Packet checking...
[00012923]Packet vlink 01.00.0030 <-> 01.00.0030.
[00012964]Record vlink 01.00.0029 <-> 01.00.0000 (flow = 0).
[00012999]Done.
[00013034]Version checking[1]...
[00013076][01 00][00] v0.34.3973 -> v0.34.3973
[00013114][01 01][00] v0.34.3973 -> v0.34.3973
[00013160][01 04][00] v0.1.3964 -> v0.1.3977 need upgrade
[00013200][04 00][00] v1.28.0.4 -> v1.28.0.5 need upgrade.
[00013253][08 00][00] v2.14.9.17 -> v2.14.9.17
[00013290]Done.
[00015326]Waiting for user confirm...
[00025367]Timeout, start upgrade automatically.
[00025441]Firmware upgrading[1]...
[00025504][01 04] Firmware upgrade start...
[00062750][01 04] Firmware upgrade finished successfully.
[00062815][04 00] Firmware upgrade start...
[00134251][04 00] Firmware upgrade finished successfully.
[00134293]Done.
[00134327]Version checking[2]...
[00134364][01 00][00] v0.34.3973 -> v0.34.3973
[00134407][01 01][00] v0.34.3973 -> v0.34.3973
[00134450][01 04][05] v0.1.3977 -> v0.1.3977
[00134527][04 00][05] v1.28.0.5 -> v1.28.0.5
[00134574][08 00][00] v2.14.9.17 -> v2.14.9.17
[00134609]Packet upgrade finish successfully.
[00006599]========== remo-con disconnect. boot(15) ============
[00006645]Packet [C:\WM610_FC550_FW_V01.04.00.70.bin] detected, card sn [0x40ce57b4].
[00006693]Packet upgrade start...
[00006746]Packet checking...
[00006794]Packet vlink 01.04.0070 <-> 01.03.0060.
[00006942]Record vlink 01.00.0030 <-> 01.00.0030 (flow = 0).
[00007008]Done.
[00007052]Version checking[1]...
[00007104][01 00][00] v1.27.5134 -> v1.19.4923
[00007154][01 01][00] v1.27.5134 -> v1.19.4923
[00007225][01 04][00] v0.5.5085 -> v0.2.4270
[00007306][04 00][00] v1.29.0.92 -> v1.29.0.85
[00007394][03 05][00] v34.1.0.5 -> v34.1.0.5
[00007477][03 06][00] v2.4.10.7 -> v2.4.10.7
[00007554][05 00][00] v3.0.6.2 -> v3.0.6.2
[00020116][08 00][00] device not detected.
[00020179][09 00][00] v3.0.0.4 -> v1.8.0.0
[00020274][11 00][00] v3.9.0.0 -> v3.8.15.4
[00020374][12 00][00] v1.11.0.0 -> v1.11.0.0
[00020475][12 01][00] v1.11.0.0 -> v1.11.0.0
[00020576][12 02][00] v1.11.0.0 -> v1.11.0.0
[00020675][12 03][00] v1.11.0.0 -> v1.11.0.0
[00033229][15 00][00] device not detected.
[00033301][17 00][00] v1.1.0.4 -> v1.1.0.4
[00033415][17 01][00] v2.0.1.4 -> v2.0.1.2
[00033470][19 00][00] v1.0.8.96 -> v1.0.8.96
[00035517]Packet upgrade failed at version checking.
[00008869]========== remo-con disconnect. boot(15) ============
[00008917]Packet [C:\WM610_FC550_FW_V01.04.00.70.bin] detected, card sn [0x40ce57b4].
[00008961]Packet upgrade start...
[00009013]Packet checking...
[00009061]Packet vlink 01.04.0070 <-> 01.03.0060.
[00009108]Record vlink 01.00.0030 <-> 01.00.0030 (flow = 0).
[00009150]Done.
[00009200]Version checking[1]...
[00009244][01 00][00] v1.27.5134 -> v1.19.4923
[00009286][01 01][00] v1.27.5134 -> v1.19.4923
[00009363][01 04][00] v0.5.5085 -> v0.2.4270
[00009415][04 00][00] v1.29.0.92 -> v1.29.0.85
[00009481][03 05][00] v34.1.0.5 -> v34.1.0.5
[00009562][03 06][00] v2.4.10.7 -> v2.4.10.7
[00009640][05 00][00] v3.0.6.2 -> v3.0.6.2
[00022179][08 00][00] device not detected.
[00022241][09 00][00] v3.0.0.4 -> v1.8.0.0
[00022321][11 00][00] v3.9.0.0 -> v3.8.15.4
[00022421][12 00][00] v1.11.0.0 -> v1.11.0.0
[00022521][12 01][00] v1.11.0.0 -> v1.11.0.0
[00022621][12 02][00] v1.11.0.0 -> v1.11.0.0
[00022821][12 03][00] v1.11.0.0 -> v1.11.0.0
[00035365][15 00][00] device not detected.
[00035441][17 00][00] v1.1.0.4 -> v1.1.0.4
[00035562][17 01][00] v2.0.1.4 -> v2.0.1.2
[00035616][19 00][00] v1.0.8.96 -> v1.0.8.96
[00037665]Packet upgrade failed at version checking.
[00007078]========== remo-con disconnect. boot(15) ============
[00007127]Packet [C:\WM610_FC550_FW_V01.08.01.00.bin] detected, card sn [0x40ce57b4].
[00007174]Packet upgrade start...
[00007228]Packet checking...
[00007274]Packet vlink 01.08.0100 <-> 01.04.0070.
[00007323]Record vlink 01.00.0030 <-> 01.00.0030 (flow = 0).
[00007367]Done.
[00007423]Version checking[1]...
[00007466][01 00][00] v1.27.5134 -> v1.22.5037
[00007517][01 01][00] v1.27.5134 -> v1.22.5037
[00007576][01 04][00] v0.5.5085 -> v0.2.4270
[00007654][03 05][00] v34.1.0.5 -> v34.1.0.5
[00007714][03 06][00] v2.4.10.7 -> v2.4.10.7
[00007769][04 00][00] v1.29.0.92 -> v1.29.0.92
[00007853][05 00][00] v3.0.6.2 -> v3.0.6.2
[00020395][08 00][00] device not detected.
[00020457][09 00][00] v3.0.0.4 -> v3.0.0.4
[00020554][11 00][00] v3.9.0.0 -> v3.9.0.0
[00020654][12 00][00] v1.11.0.0 -> v1.11.0.0
[00020754][12 01][00] v1.11.0.0 -> v1.11.0.0
[00020854][12 02][00] v1.11.0.0 -> v1.11.0.0
[00020955][12 03][00] v1.11.0.0 -> v1.11.0.0
[00033500][15 00][00] device not detected.
[00033600][17 00][00] v1.1.0.4 -> v1.1.0.4
[00033713][17 01][00] v2.0.1.4 -> v2.0.1.4
[00033777][19 00][00] v1.0.8.96 -> v1.0.8.96
[00035816]Packet upgrade failed at version checking.
[00006629]========== remo-con disconnect. boot(15) ============
[00006680]Packet [C:\WM610_FC550_FW_V01.04.00.70.bin] detected, card sn [0x40ce57b4].
[00006726]Packet upgrade start...
[00006785]Packet checking...
[00006831]Packet vlink 01.04.0070 <-> 01.03.0060.
[00006883]Record vlink 01.00.0030 <-> 01.00.0030 (flow = 0).
[00006930]Done.
[00006997]Version checking[1]...
[00007041][01 00][00] v1.27.5134 -> v1.19.4923
[00007097][01 01][00] v1.27.5134 -> v1.19.4923
[00007308][01 04][00] v0.5.5085 -> v0.2.4270
[00007378][04 00][00] v1.29.0.92 -> v1.29.0.85
[00007466][03 05][00] v34.1.0.5 -> v34.1.0.5
[00007541][03 06][00] v2.4.10.7 -> v2.4.10.7
[00007640][05 00][00] v3.0.6.2 -> v3.0.6.2
[00020190][08 00][00] device not detected.
[00020256][09 00][00] v3.0.0.4 -> v1.8.0.0
[00020340][11 00][00] v3.9.0.0 -> v3.8.15.4
[00020440][12 00][00] v1.11.0.0 -> v1.11.0.0
[00020540][12 01][00] v1.11.0.0 -> v1.11.0.0
[00020641][12 02][00] v1.11.0.0 -> v1.11.0.0
[00020741][12 03][00] v1.11.0.0 -> v1.11.0.0
[00033290][15 00][00] device not detected.
[00033381][17 00][00] v1.1.0.4 -> v1.1.0.4
[00033501][17 01][00] v2.0.1.4 -> v2.0.1.2
[00033570][19 00][00] v1.0.8.96 -> v1.0.8.96
[00035621]Packet upgrade failed at version checking.
[00006625]========== remo-con disconnect. boot(15) ============
[00006672]Packet [C:\WM610_FC550_FW_V01.08.01.00.bin] detected, card sn [0x40ce57b4].
[00006717]Packet upgrade start...
[00006781]Packet checking...
[00006831]Packet vlink 01.08.0100 <-> 01.04.0070.
[00006879]Record vlink 01.00.0030 <-> 01.00.0030 (flow = 0).
[00006931]Done.
[00007014]Version checking[1]...
[00007086][01 00][00] v1.27.5134 -> v1.22.5037
[00007130][01 01][00] v1.27.5134 -> v1.22.5037
[00007200][01 04][00] v0.5.5085 -> v0.2.4270
[00007266][03 05][00] v34.1.0.5 -> v34.1.0.5
[00007348][03 06][00] v2.4.10.7 -> v2.4.10.7
[00007409][04 00][00] v1.29.0.92 -> v1.29.0.92
[00007507][05 00][00] v3.0.6.2 -> v3.0.6.2
[00020055][08 00][00] device not detected.
[00020122][09 00][00] v3.0.0.4 -> v3.0.0.4
[00020226][11 00][00] v3.9.0.0 -> v3.9.0.0
[00020326][12 00][00] v1.11.0.0 -> v1.11.0.0
[00020447][12 01][00] v1.11.0.0 -> v1.11.0.0
[00020548][12 02][00] v1.11.0.0 -> v1.11.0.0
[00020647][12 03][00] v1.11.0.0 -> v1.11.0.0
[00033197][15 00][00] device not detected.
[00033266][17 00][00] v1.1.0.4 -> v1.1.0.4
[00033391][17 01][00] v2.0.1.4 -> v2.0.1.4
[00033452][19 00][00] v1.0.8.96 -> v1.0.8.96
[00035601]Packet upgrade failed at version checking.
[00006986]========== remo-con disconnect. boot(15) ============
[00007043]Packet [C:\WM610_FC550_FW_V01.04.00.70.bin] detected, card sn [0x40ce57b4].
[00007100]Packet upgrade start...
[00007154]Packet checking...
[00007227]Packet vlink 01.04.0070 <-> 01.03.0060.
[00007275]Record vlink 01.00.0030 <-> 01.00.0030 (flow = 0).
[00007336]Done.
[00007384]Version checking[1]...
[00007452][01 00][00] v1.27.5134 -> v1.19.4923
[00007551][01 01][00] v1.27.5134 -> v1.19.4923
[00007621][01 04][00] v0.5.5085 -> v0.2.4270
[00007674][04 00][00] v1.29.0.92 -> v1.29.0.85
[00007764][03 05][00] v34.1.0.5 -> v34.1.0.5
[00007844][03 06][00] v2.4.10.7 -> v2.4.10.7
[00007928][05 00][00] v3.0.6.2 -> v3.0.6.2
[00020476][08 00][00] device not detected.
[00020544][09 00][00] v3.0.0.4 -> v1.8.0.0
[00020612][11 00][00] v3.9.0.0 -> v3.8.15.4
[00020711][12 00][00] v1.11.0.0 -> v1.11.0.0
[00020824][12 01][00] v1.11.0.0 -> v1.11.0.0
[00020924][12 02][00] v1.11.0.0 -> v1.11.0.0
[00021024][12 03][00] v1.11.0.0 -> v1.11.0.0
[00033586][15 00][00] device not detected.
[00033664][17 00][00] v1.1.0.4 -> v1.1.0.4
[00033764][17 01][00] v2.0.1.4 -> v2.0.1.2
[00033825][19 00][00] v1.0.8.96 -> v1.0.8.96
[00035873]Packet upgrade failed at version checking.
[00006718]========== remo-con disconnect. boot(15) ============
[00006769]Packet [C:\WM610_FC550_FW_V01.04.00.70.bin] detected, card sn [0x40ce57b4].
[00006820]Packet upgrade start...
[00006881]Packet checking...
[00006936]Packet vlink 01.04.0070 <-> 01.03.0060.
[00006983]Record vlink 01.00.0030 <-> 01.00.0030 (flow = 0).
[00007054]Done.
[00007125]Version checking[1]...
[00007175][01 00][00] v1.27.5134 -> v1.19.4923
[00007217][01 01][00] v1.27.5134 -> v1.19.4923
[00007278][01 04][00] v0.5.5085 -> v0.2.4270
[00007338][04 00][00] v1.29.0.92 -> v1.29.0.85
[00007428][03 05][00] v34.1.0.5 -> v34.1.0.5
[00007528][03 06][00] v2.4.10.7 -> v2.4.10.7
[00007608][05 00][00] v3.0.6.2 -> v3.0.6.2
[00020245][08 00][00] device not detected.
[00020316][09 00][00] v3.0.0.4 -> v1.8.0.0
[00020416][11 00][00] v3.9.0.0 -> v3.8.15.4
[00020528][12 00][00] v1.11.0.0 -> v1.11.0.0
[00020628][12 01][00] v1.11.0.0 -> v1.11.0.0
[00020748][12 02][00] v1.11.0.0 -> v1.11.0.0
[00020848][12 03][00] v1.11.0.0 -> v1.11.0.0
[00033396][15 00][00] device not detected.
[00033491][17 00][00] v1.1.0.4 -> v1.1.0.4
[00033607][17 01][00] v2.0.1.4 -> v2.0.1.2
[00033682][19 00][00] v1.0.8.96 -> v1.0.8.96
[00035737]Packet upgrade failed at version checking.
Osmo:
[00012742]========== remo-con disconnect. boot(15) ============
[00012856]Packet [C:\OSMO_FC550_FW_V01.01.00.10.bin] detected, card sn [0x40ce57b4].
[00012898]Packet upgrade start...
[00012941]Packet checking...
[00012982]Packet vlink 01.01.0010 <-> 01.01.0000.
[00013054]Done.
[00013094]Version checking[1]...
[00013222][07 00][00] v1.0.9.48 -> v1.0.9.48
[00025763][08 00][00] device not detected.
[00025803][01 00][00] v0.34.3973 -> v1.27.5134 need upgrade
[00025844][01 01][00] v0.34.3973 -> v1.27.5134 need upgrade
[00038387][01 04][00] device not detected.
[00038439][04 00][00] v1.28.0.8 -> v1.29.0.92 need upgrade.
[00038522][09 00][00] v0.0.0.88 -> v0.0.0.88
[00038561]Done.
[00040602]Waiting for user confirm...
[00050644]Timeout, start upgrade automatically.
[00050725]Firmware upgrading[1]...
[00056715][01 00] Firmware upgrade start...
[00009473][01 00] Firmware upgrade finished successfully.
[00009512]Done.
[00009554]Packet [C:\OSMO_FC550_FW_V01.01.00.10.bin] resumed, card sn [0x40ce57b4].
[00009602]Packet vlink 01.01.0010 <-> 01.01.0000.
[00009677]Version checking[2]...
[00009737][07 00][00] v1.0.9.48 -> v1.0.9.48
[00022284][08 00][00] device not detected.
[00022323][01 00][05] v1.27.5134 -> v1.27.5134
[00022367][01 01][00] v0.34.3973 -> v1.27.5134 need upgrade
[00022418][01 04][00] v0.1.3977 -> v0.5.5085 need upgrade
[00022485][04 00][00] v1.28.0.8 -> v1.29.0.92 need upgrade.
[00022536][09 00][00] v0.0.0.88 -> v0.0.0.88
[00022580]Done.
[00022619]Firmware upgrading[2]...
[00022722][01 01] Firmware upgrade start...
[00033019][01 01] Firmware upgrade finished successfully.
[00033070][01 04] Firmware upgrade start...
[00052471][01 04] Firmware upgrade finished successfully.
[00052549][04 00] Firmware upgrade start...
[00106063][04 00] Firmware upgrade finished successfully.
[00106104]Done.
[00106143]Version checking[3]...
[00106214][07 00][00] v1.0.9.48 -> v1.0.9.48
[00118776][08 00][00] device not detected.
[00118818][01 00][05] v1.27.5134 -> v1.27.5134
[00118958][01 01][05] v1.27.5134 -> v1.27.5134
[00121506][01 04][05] device not detected, reset device.
[00123558][01 04][05] v0.5.5085 -> v0.5.5085
[00123611][04 00][05] v1.29.0.92 -> v1.29.0.92
[00123663][09 00][00] v0.0.0.88 -> v0.0.0.88
[00123712]Packet upgrade failed at version checking.
[00010582]========== remo-con disconnect. boot(15) ============
[00010625]Packet [C:\OSMO_FC550_FW_V01.01.00.10.bin] detected, card sn [0x40ce57b4].
[00010665]Packet upgrade start...
[00010716]Packet checking...
[00010759]Packet vlink 01.01.0010 <-> 01.01.0000.
[00010839]Done.
[00010880]Version checking[1]...
[00010950][07 00][00] v1.0.9.48 -> v1.0.9.48
[00023488][08 00][00] device not detected.
[00023537][01 00][00] v1.27.5134 -> v1.27.5134
[00023579][01 01][00] v1.27.5134 -> v1.27.5134
[00023634][01 04][00] v0.5.5085 -> v0.5.5085
[00023683][04 00][00] v1.29.0.92 -> v1.29.0.92
[00023739][09 00][00] v0.0.0.88 -> v0.0.0.88
[00025784]Packet upgrade failed at version checking.
[00010609]========== remo-con disconnect. boot(15) ============
[00010652]Packet [C:\OSMO_FC550_FW_V01.01.00.10.bin] detected, card sn [0x40ce57b4].
[00010704]Packet upgrade start...
[00010755]Packet checking...
[00010812]Packet vlink 01.01.0010 <-> 01.01.0000.
[00010889]Done.
[00010932]Version checking[1]...
[00011005][07 00][00] v1.0.9.48 -> v1.0.9.48
[00023549][08 00][00] device not detected.
[00023598][01 00][00] v1.27.5134 -> v1.27.5134
[00023645][01 01][00] v1.27.5134 -> v1.27.5134
[00023700][01 04][00] v0.5.5085 -> v0.5.5085
[00023758][04 00][00] v1.29.0.92 -> v1.29.0.92
[00023823][09 00][00] v0.0.0.88 -> v0.0.0.88
[00025867]Packet upgrade failed at version checking.
[00010567]========== remo-con disconnect. boot(15) ============
[00010606]Packet [C:\OSMO_FC550_FW_V01.01.00.10.bin] detected, card sn [0x40ce57b4].
[00010648]Packet upgrade start...
[00010696]Packet checking...
[00010742]Packet vlink 01.01.0010 <-> 01.01.0000.
[00010907]Done.
[00010951]Version checking[1]...
[00011021][07 00][00] v1.0.9.48 -> v1.0.9.48
[00023576][08 00][00] device not detected.
[00023620][01 00][00] v1.27.5134 -> v1.27.5134
[00023667][01 01][00] v1.27.5134 -> v1.27.5134
[00023719][01 04][00] v0.5.5085 -> v0.5.5085
[00023781][04 00][00] v1.29.0.92 -> v1.29.0.92
[00023848][09 00][00] v0.0.0.88 -> v0.0.0.88
[00025892]Packet upgrade failed at version checking.
[00006636]========== 2016.06.10 16:57:00. boot(15) ============
[00006685]Packet [C:\OSMO_FC550_FW_V01.01.00.10.bin] detected, card sn [0x40ce57b4].
[00006729]Packet upgrade start...
[00006778]Packet checking...
[00006824]Packet vlink 01.01.0010 <-> 01.01.0000.
[00006906]Done.
[00006950]Version checking[1]...
[00007111][07 00][00] v1.0.9.48 -> v1.0.9.48
[00019679][08 00][00] device not detected.
[00019722][01 00][00] v1.27.5134 -> v1.27.5134
[00019768][01 01][00] v1.27.5134 -> v1.27.5134
[00019816][01 04][00] v0.5.5085 -> v0.5.5085
[00019874][04 00][00] v1.29.0.92 -> v1.29.0.92
[00019932][09 00][00] v0.0.0.88 -> v0.0.0.88
[00021979]Packet upgrade failed at version checking.
[00006911]========== 2016.06.10 17:02:29. boot(15) ============
[00006958]Packet [C:\OSMO_FC550_FW_V01.01.00.10.bin] detected, card sn [0x40ce57b4].
[00007006]Packet upgrade start...
[00007056]Packet checking...
[00007098]Packet vlink 01.01.0010 <-> 01.01.0000.
[00007171]Done.
[00007219]Version checking[1]...
[00007294][07 00][00] v1.0.9.48 -> v1.0.9.48
[00019838][08 00][00] device not detected.
[00019882][01 00][00] v1.27.5134 -> v1.27.5134
[00019923][01 01][00] v1.27.5134 -> v1.27.5134
[00019983][01 04][00] v0.5.5085 -> v0.5.5085
[00020033][04 00][00] v1.29.0.92 -> v1.29.0.92
[00020093][09 00][00] v0.0.0.88 -> v0.0.0.88
[00022136]Packet upgrade failed at version checking.
[00006609]========== 2016.06.10 17:04:12. boot(15) ============
[00006651]Packet [C:\OSMO_FC550_FW_V01.01.00.10.bin] detected, card sn [0x40ce57b4].
[00006773]Packet upgrade start...
[00006821]Packet checking...
[00006868]Packet vlink 01.01.0010 <-> 01.01.0000.
[00006940]Done.
[00006982]Version checking[1]...
[00007059][07 00][00] v1.0.9.48 -> v1.0.9.48
[00019602][08 00][00] device not detected.
[00019646][01 00][00] v1.27.5134 -> v1.27.5134
[00019692][01 01][00] v1.27.5134 -> v1.27.5134
[00019740][01 04][00] v0.5.5085 -> v0.5.5085
[00019788][04 00][00] v1.29.0.92 -> v1.29.0.92
[00019866][09 00][00] v0.0.0.88 -> v0.0.0.88
[00021909]Packet upgrade failed at version checking.
[00006619]========== 2016.06.10 17:07:51. boot(15) ============
[00006663]Packet [C:\OSMO_FC550_FW_V01.01.00.10.bin] detected, card sn [0x40ce57b4].
[00006705]Packet upgrade start...
[00006752]Packet checking...
[00006805]Packet vlink 01.01.0010 <-> 01.01.0000.
[00006880]Done.
[00006922]Version checking[1]...
[00007002][07 00][00] v1.0.9.48 -> v1.0.9.48
[00019545][08 00][00] device not detected.
[00019586][01 00][00] v1.27.5134 -> v1.27.5134
[00019632][01 01][00] v1.27.5134 -> v1.27.5134
[00019682][01 04][00] v0.5.5085 -> v0.5.5085
[00019730][04 00][00] v1.29.0.92 -> v1.29.0.92
[00019790][09 00][00] v0.0.0.88 -> v0.0.0.88
[00021837]Packet upgrade failed at version checking.
