Oleksiy
Switzerland
I had a look at weather in Hamburg region on March 22, 2016:
https://www.wunderground.com/his ... c=3&reqdb.wmo=10147
It was 7 degree Celsius in the morning, and wind about 19 km/h, at times a light rain. I would recommend on cool days to initialize motors and let motors to run idle for about a minute to warm up. And then to start flying at first slowly, - to let mechanics and electronics to warm up.
I had a problem with my trainer, a small quadcopter Blade QX 200, recently. On a cold morning I started to pilot it a bit too aggressively right from the beginning and after two minutes in the air it started to drop from the sky without any apparent reason. I barely could avoid falling into a river. One leg of a landing gear was broken during the hard landing, nearly a crash. Fortunately, it was repairable.
Later, the same morning I could fly with the same battery still 4 minutes. So the battery was well charged, but probably I drew too much energy too fast from it.
So now I let the aircraft, including my P3A, to warm up a bit, first on the ground and then in the air, before starting to fly fast, and insert into a flight some calm moments to let the chemical reaction in the battery to replenish the energy. |
