Hi everybody!
I have a P3S, and I'm using Litchi for iOS to make my footages since it was compatible with P3S.
Today, I was flying using waypoints, and I realized that my bird was shaking sometime, and I don't know what can be.
In the link bellow, you can watch the issue:
Please, seek the video to 2:08 or 3:11.
There was no wind, all the propelers are balanced, and the bird was cruising at 25km/h only. The gimbal is working fine as well.
This issue doesn't happen with dji go app, only with litchi.
It looks like mine when I play with the yaw during a programed gimbal flight. It always snaps back when I let go of the stick.
Try a new mission and be sure the Focus and Interpolate controls are the way you want them.
Before this mission, I flew a mission with no issues.
I thought it could be a kind of interference, but I was in the countryside (no cellphone and wifi signal).
Rnfaust Posted at 2016-3-24 01:05
It looks like mine when I play with the yaw during a programed gimbal flight. It always snaps back w ...
Hi Rnfaust,
I'm using Focus POI in my missions, but it's not working very well. After the second POI the gimbal starts to work. If I put focus POI and Interpolate together in the same mission, sometimes it works and sometimes don't. Very weird behavior.
Is that happening in different /new missions or just the one?
I don't mix my POI's with Interpolates, but I read that there must be at least 2 consecutive Interpolates for it to work.
Yours is a strange situation for sure. Just keep in mind that you can override the yaw by touching the stick. All I can think of. Try Litchi Support online.
Hi Juliano
I looked at your Litchi mission and it looks normal except possibly the altitude. I guess it's ok, but do you think your P3 has an altitude limit set in the Go app that is in conflict with Litchi? Those controls parameters are kept in the drone, not just in the app.
You were approaching 305 meters altitude at at least 1 wp. I also wonder if the drone would be able to drop from 250 to 30 meters between wp 7-8 doing 26 kmh? That might present a conflict. Are there any altitude restrictions in Brazil?
From what I have read on a couple of other forums after experiencing the same issues myself it would appear that the Litchi App causes gimbal twitching or shudder when the drone is descending while moving in a forward direction. I flew two quite long missions yesterday (7.5kms and 5kms) and upon reviewing the footage I noticed that both did the same thing when the aircraft was descending between waypoints. In both cases the descent between the two waypoints in question were quite large (between 60-80 metres of height) so I might try and add a few intermediate waypoints to 'smooth' out the descent path and see if this makes any difference.
