terrylewis
Flight distance : 3517287 ft
The simple rule for compass calibration is to calibrate your compass when it's needed. Well, that's double talk!....... When is it needed?
The compass sensor is a three axis device that measures x (north/south); y (east/west) deviations and z, vertical inclination. We should always calibrate the compass the first time we fly in a new area. And possibly after firmware upgrades. We simply calibrate by rotating the horizontal and vertical axis of the Inspire with no magnetic influence within 5 meters of your aircraft (absolutely no metal).
With this first calibration, we should inspect and record the Compass sensor MOD value under MC Settings/Advanced Settings/Sensors in the GO App. The MOD value should be around 1500. Fly your aircraft conservatively, expecting to switch to A-Mode if necessary. If the Compass MOD value is around 1500 and the aircraft flies well, then your calibration is a keeper. You won't need to recalibrate unless the MOD value increases or decreases significantly, or you move to fly in a new location. DJI says about 150 miles because the earths magnetic variation changes at about that distance.
So what the heck is this MOD value?
DJI gives us a statistical measure of our calibrations within the GO App under MC Settings/Advanced Settings/Sensors for the gyro, the accelerometer, and the compass. If we watch these values with each flight, we will know if our IMU or Compass needs recalibration. These sensor readings include the three axis readings but the fourth column is the one that matters. The MOD values are "Root-Sum-Square" measures of the accuracy of your calibration. The three compass values should always generate a MOD around 1500. Always check your sensors before takeoff and when the aircraft is level, look for MOD values of 0.00 for gyros, 1.00 for acceleration, and the compass fluctuating around 1500. If it's significantly different, you need to re-calibrate.... Simple!
Best of luck with your test and always Fly Safe! |
