FatedFilmsNC
That is the VPS? (correct me if i'm naming the wrong feature) or whatever the sonar sensors on the bottom are called. They dictate what altitude your drone will fly at due to what it's reading from what it's hearing from echoes it's sending to the ground. That's why it only happens sometimes. It happens when you fly below 10m over a repeated surface, such as water, grass, probably road, etc. It's in the manual.
edit** probably road without traffic lines painted on**
