New SD Card Phantom 3 Advanced
RonAruba
Aruba
Hi all,
Just bought a new SD card for the Phantom 3 advanced.
Is it just plug and play? Or do I have to copy some files to it first?
If yes which files?
Regards, Ron
(  Is formatting enough?  )
2016-4-2
Geebax
You do not have to copy any files onto it, that is only necessary if you are performing a firmware upgrade. Formatting is necessary, but the best way to do that is to format in the camera using the DJI Go App. THen the aircraft will set up all the directories and hidden files it needs.
If you are on Aruba, I would love to see some footage from there.
2016-4-2
RonAruba
Aruba
Hi Thanks for the answer.
I live on Aruba, and I have a lot of footage. Also yesterday I came back from Bonaire and had some filming there.
How do you guys usually share footage? Where?
2016-4-2
starman560
just Delete any thing on the SD card so its Blank ,,, and the Phantom will make the files for you
Russ
2016-4-2
