Donnie
Flight distance : 3636782 ft
Michael , Was there any damage to the Props\ Motors when you crashed? Be sure to replace all your props and make sure none of the motor or motor mounts are cracked. look specifically for cracks and any loose motor screws on the bottom of the motor mount areas . Look closely at the runout of the blades . If you ever flew model helicopters this was common practice to see which blade was slightly pitched higheer than the other. In your case just get it up to Eye level ( just be back about 3 or 4 feet , in a hover or even while on the ground and with safety glasses look for one of those motors shaking or blades out of alignment . With the amount of vibration, If one is bad it should be easy to spot . Make sure none of the plastic gimbal ball camera mounts is not ripped as well . This is a pretty severe vibration and my money would be on one of the motors being damaged from the crash, it does not take much to bend the Main shaft of the Electric motor or one of it components and the props, be sure to replace them as well . I would focus on what ever ares were damaged from the crash and look closely to these areas. Hope this helps. Be sure to do the IMU and Camera calibrations after a crash as well as the compass for sure. I dont think that this is causing your vibration ( Pretty severe) but it is good procedure regardless after a crash .
Also listen for unusual noises from the Gimbal motors, with the aircraft on but props off just take and pitch the aircraft around, see if you hear a buzzing or something out of sorts, yaw the aircraft as well, once again listening to one of the motors giving a strange noise or grind . Just do normal movements as if the craft was airborn . Make sure no dirt or debris from the crash got into the gimbal motors, blow them out gently with computer sprayers or compressed air,Only do this if dirt could have gotten lodged in there from the crash. Also simply listen intently while the camera is doing the start up dance for any thing that sounds goofy.
I would once again concentrate on areas that were damaged in the crash and work my way out from there.
Let me lnow what you find out, I am curious
Which model specifically is this ( sorry if I missed it )
Good luck - donnie
