microcyb
Flight distance : 1095955 ft
Well first you need to insure you are running the latest version of the DJI Go application.
Do not perform the firmware update till you have this done.
OK moving on.
Make sure you have enough battery levels on both your controller and bird.
Insure you have downloaded the the firmware onto your phone/tablet.
When you perform the firmware update, do not touch anything from your phone, controller, and drone. The update can take up to 30 minutes.
Once update is complete, turn off your drone, and the controller then back on.
A re-link might be required, but these steps should be all you need to do.
