labroides
Flight distance : 9991457 ft
Your firmware adventures should not have had any effect on the compass.
Check the sensors info in the app and make sure you have some sort of number showing for the compass.
If it shows zero you have a real problem and the compass is busted or disconnected.
If there's a number there, you should be able to calibrate it in a good area away from magnetic interference (cars, structural steel, reinforced concrete etc) |
