na5n
Welcome to the forum and your new P3S. I have a P2V+ and a P3S and enjoy them both. I'm going to repeat mostly what has been said.
1. Read the manual - twice, if not three times. The P3S does not come with a printed manual, so download it (.pdf) from the DJI site under Phantom and Downloads. Take notes, jot down the meaning of the flashing LEDs, etc.
2. If you're confused or uncertain on anything, check the tutorial videos on the DJI site and YouTube.
3. Before your first flight, yes, put your name and phone number on the bird somewhere in case you loose it behind those trees due to inexperience. Register with the FAA; also put number on the bird.
4. Get as familiar as you can with the DJI GO app. Especially the battery level, the number of GPS satellites, and the button to initiate Return to Home.
5. On your first flight, do the pre-checks and compass calibration. Pick a nice open field away from trees, tall buildings, power lines and water. Running into a tree, building, or dunking it water almost guarantees that's your last flight! Take off and maneuver your Phantom to fly in a large square, then a circle, take it up, then down, not too fast, to get a feel of the controls and how to fly it to where you want. Sure, take some photos or record some video to see what it looks like, but on your first few flights, you should concentrate on flying and maneuvering the Phantom, not photography. Doing both well takes a lot of practice. Keep it within visual range at all times. Fly it out of sight and maneuver with the FPV video only after you build up plenty of confidence.
6. On your first flight or two, bring it home with the RTH (return to home) to get a feel of how that works, the return altitude (in case you want to make it higher), how long it takes, and how close it comes to the take off point to land. On your flights, anything goes wrong or you send it too far away, or something, RTH can save your skin (if nothing tall in between you and the Phantom) to get it back to you safe.
7. After a couple of flights, you are excited to go send it somewhere really neat. Don't get too exotic at first. Just remain conservative with your flights until you get comfortable with the bird. Maybe 2-3 flights, maybe a dozen. Your mileage may vary.
8. A big problem for many of us at first is keeping track of the orientation of the Phantom. That is, you yaw it around to take photos and you loose track of which way it's heading. You pull your right stick to bring it home, and it flies off in a completely different direction. Learn to watch the GO app for the orientation to know the heading of the bird (the arms with the red flashing LEDs defines the front of the Phantom - the same side as the camera). Another reason not to fly it out of sight until you've mastered orientation and using the Home Lock function.
It's not really that hard, and gobs of fun. Just be conservative at first and really learn how to maneuver the Phantom. A good flight is no problem. Where you get into trouble is when you loose GPS lock or something. Learning to recover when things go wrong is the key to many flights to come.
Good luck, have fun, and let us know your progress.
