endotherm
Flight distance : 503241 ft
That's an interesting observation. I wonder if the camera isn't catching the side wind like a sail, and the roll/tilt is being introduced as the camera assembly is pushed to the side? I imagine the camera is referenced to the lower plate, but this will be pushed out of horizontal/flat with a big enough crosswind. From the front or rear, the camera will be looking a couple of degrees higher or lower, but it probably won't be obvious, at least the horizon is level. I don't know where the sensors are physically located, and I wonder if a few degrees out of parallel in the gimbal plates translates to being off-horizontal by the same amount? As an example, if the aircraft has a 45 degree roll, it will introduce a -45 degree roll of the camera to keep it level. But those angles are with respect to the top gimbal plate/base of the aircraft. If there are a few extra degrees introduced by a crosswind, the sensor may not be aware that the bottom plate is not where it expects it to be.
