wayneparris911
Flight distance : 214357 ft
I'm having a couple issues that I can't figure out with my P3P.
1. Image Transmission Weak---I haven't changed anything. My images send back to my iPhone or iPad used to be crystal clear. Now they are choppy and incomplete. I can see the top half of the image clearly for the most part, but the lower half looks like a digital loss of signal. The images appear fine on the SD card.
2. Does not maintain altitude--While in a hover in GPS mode, if will sometimes start a decsent. If I'm at a hover and performing a different task, the aircraft will start a decsending. I can attempt to raise it back up, but it will keep going down. I have had to get forward airspeed and use transitional lift to start a climp to keep it from landing somewhere far away. I will note that I was close to a no-fly zone when this occurred, but well outside it.
3. Upgrading the firmware--I am attempting to do the latest upgrade. I put the SD card in the aircraft and immediately heard a "D-DD" indicating that the upgrade is complete, however, the red LED light is blinking and the lights on the rear of the aircraft are flashing amber.
4. When I climb from takeoff, the aircraft wants to yaw. I can't figure out how to calibrate the sticks. I've had the aircraft for a year and fly it quite a bit.
Any help is much appreciated!!
