LiPo Charging Question
809 4 2015-1-14
mikeatlincoln
I have a couple of questions on LiPo charging for the Vision 2+. I know that for storage the battery should be at 50% charge. Can I charge it to 50% after use and then finish charging the day I want to fly? If so, should I just unplug the charging cable from the battery while it's running or should I unplug the AC input to the charger first?
2015-1-14
Gerry1124
You can do it either way you want.
2015-1-14
Gunny Huntarr
There is a pattern to long term storage
pg 10 of your manual
section 2.5
step 3
2015-1-14
mike
Flight distance : 228255 ft
mikeatlincoln, if you have the most recent battery firmware, your batteries will auto discharge to ~50% after 10 days. So, it's also safe to store them fully charged.
2015-1-14
mikeatlincoln
mike@singerscre Posted at 2015-1-15 10:08
mikeatlincoln, if you have the most recent battery firmware, your batteries will auto discharge to ~ ...
When I referred to storage I was thinking short term. (A week or less) I want to treat the LiPo in the best possible manner. So maybe 100% or 50% for a week doesn't make a difference? Also I was concerned about unplugging the charger plug while current was flowing. (Possible arcing)
2015-1-14
