Northofthe49th
Think of home point as "0'" regardless of your physical altitude...again, disregard your actual physical altitude....weather it be above or below sea level.""
When you take off, let's say at 2,500' above sea level, your home point with reference from where you took off is "0'"...so if you fly up 200' and do an RTH (depends what you have it set to) it will be referenced from your "0'" home point from where you took off...
If you take off at ie. 2,500' and climb down a hill 500' and initiate an RTH your bird will climb to the 200' above your take off point which was 2,500'....
It is always referenced from your takeoff location/altitude.... |
