martin_harrow
Same here, RC update was fine but AC failed after about 15 minutes...
========== 2014.01.01 00:00:10 remo-con disconnect======
Packet: P3S_FW_V01.08.0080.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
Get the same result with a different SD card...App says everything is up to date but really concerned about flying with apparently corrupt firmware...
DJI tech support absolutely no help (only suggested resetting my ipad...which wasn't connected so had nothing to do with the FW install or result!)
I've got a F550 and P2 so no stranger to DJI updates, and never had a problem in the past...their other suggestion was to send it off for "repair"...haven't even flown this bird since getting it (bad weather/work etc.) so pretty pissed off at their attitude tbh. :-/ |
