Hi ,
I am into aerial cinematogrpahy ,
From last few flights i am facing problem with my p3p , when i am making shoots the yaw gives bad shake which destroys the footage ,
Need help what to do
Thanks
Did you remove the small rubber block off the back of the gimble? Did you remove the gimble guard off the front of the gimble? You didn't upload the video showing the problems you are experiencing so we could analyze the possibilities causing the problem. We need more imput!
