Donnie
Flight distance : 3636782 ft
Kansas You must rollback the RC to 1.58 version then load the aircraft with version 1.8, then load the RC back to 1.6. ( the Aircraft will spring to life when you get 1.58 back on the RC ) YOU WERE CURRENT ON THE UPDATES TILL NOW CORRECT ? important
This is what happens when you load the RC Transmitter before the Aircraft, ( the camera goes limp and wont do anything ) Rollback the RC to 1.58 and re-establish communication between the two, ( You should not have to re- link at this point ) then load 1.8 to the AC and then update to 1.6 on the RC
Below in the next post is video on how to roillback to 1.58
Make sure you are using the proper version for the Inspire 1 the numbers look the same but I assure you they are different. If you have the Pro , be sure to use that version, if it is the standard , use that one .
Make sure the Aircraft is off when updating the RC transmitter and Make Dam sure the RC is off when updating Aircraft.
If you have any trouble rolling-back with the tutorial below, let me (Us ) know . Make sure you have a solid wi-fi connection when rolling back and make sure aircraft is OFF. Make sure you have a solid charge on I pad and RC Transmitter as well ( I-pad or whatever device go app is on )
donnie
