I have a ph3 standard im trying to get the course lock to work but when I setup everything the screen does not come up on my ipad can anyone tell me with might be wrong why the screen doesn't pop up on my ipad.. thanks
FW is firmware..........you multiple flight mode need to be enabled in the App If it is enabled and you still don't see the triangle/arrow icon on the left under RTH you may need a firmware update..........you can take off in any mode P A or F. once the switch is in F you should see the arrow thing.
ok I got it working now, when I did a update on it a few weeks ago the screen changed on everything so now what I was looking for is at the bottom of the screen and not up top.. anyway its working now and thanks for all your help.. charlie
And using the sim is a life saver to get very familiar with the process of establishing as well as canceling the flight mode in an emergency - practice to the point where you are quite comfortable switching the modes and taking control back.
GT
